Drag Chain Attachment
There is no step to attach the drag chains to the drag chain bracket on the Y Side plate or the X Carriage. I see where the holes would line up but not sure what hardware to fasten them with and at what step I should do it. I have the drag chain mounted to the extrusion bar with t-slot bolts and flat head M5 10mm scews. But where they bend up and attach to the rackes on the X carriage or the Y plate I;m just not sure what hardware to use or at what step.
Hope this helps
