Is anyone they’re using “Whole Shop” Dust System as the primary dust control on their X-carve? I am getting ready to purchase a 3hp system, either Powermatic or Laguna. I am trying to decide If I hook it to the x-carve or upgrade my shop vac for the x-carve in conjunction with the whole shop system.
Looking for some guidance on the subject. Thanks Steve
I use a modified Harbor Frieght blower with a cyclone for a whole shop system and have a line off it that goes down to a 2" hose for the cnc. I’m working on a different attachment that i can use vs the dust shroud with skirt, and looking to add a deflector for the downdraft on the DeWalt router to keep it from blowing chips all over the work surface…
I’m also curious. I was considering buying the HF collector and modifying it to work for my shop. I was curious how the dust collector worked when necked down to 2". I know these units are more about volume than pressure.
that is exactly what I will be going from/going to. Did you add a bigger cyclone for the HF collector, or are you using the standard bag setup it comes with?
I don’t have a cyclone. I did replace the original bag (5 micron) with a 1 micron bag. I’m in the process of plumbing out my whole shop, with pvc and blast gates. For now, just using 4" hose to each machine
So my DC is modified with a new impeller, cyclone and piped outside for 0 back pressure. A run of 4" duct around 30’ married to to a 4" flex @10’ and then reduced to a 2" flex at 6’ I do not notice any issue with suction and that is without any deflection for the Dewalt 611.
Correct 4" hvac duct. They have it at big box and local wholesalers. The wye and flexible 90/45 joints make it a breeze to put together. Wear good gloves and have ductwork tape on hand and you’re good to go. It’s substantially lighter to work with vs pvc and you can avoid the theoretical spark in the piping from static build up.
I have a motor already, I just need that metal cyclone collector to build one. The Super Dust Deputies are pretty pricey, and I have a feeling the sheet metal ones are going to be more affordable.
So the price for the one I got was $199 eBay Home but I am running 6" to the blower with the upgraded impeller. If you don’t modify your blower go with the 4" version and the price is cheaper.
ah. Thank you so much for that. I had been looking for a long time. Yes, is that the Rikon impeller? I thought they started required proof of ownership of their units to buy the impellers now. Is that not the case?
