@KennethConnell1 helps if I add the file
another free source would be carbide create i find very easy to use
Yeah it makes more sense now that I see that you used a circle for the handle.
Just keep in mind when designing in Easel the more complicated you make the shape the more room for error. sometime the best answer is the most simple one.
buy the way you are doing great, the more you experiment the more you will learn and the better your end results will be.
