I am sure it’s user error but I have been fighting with this one long enough and need some help. I am doing a 2 stage cut and Easel is using the smaller bit to cut the shape and tabs out and I need it to use the larger bit (the small bit is too short to cut through my material). I tried using the offset tool but that did not help.
Here is a screenshot showing the line and tool paths from Easel: Image 2017-10-28 at 11.38.0...
How can I make the cut with the larger bit? I set the cut for the line in question to “outline” and “outside” but as you can see in the tool path Easel wants to do the cut with the detail bit.
Edit: I am going to use the multi part project option to fix this for now but if anyone knows how to do it w/o having to split my carves up that would be awesome.
Thanks
