We have now set up our small business & have had a few requests for carvings. At the minute we are designing on easel then sending a screenshot of the “detailed view” to the customer for them to ok it.
Is there a way of sending a 3D image of the design to the customer, so it looks more professional, so they can see what it will look like?
I use the detail view and often manipulate the way it looks with changing depths and adding surrounding rectangles set to full depth. And get results like this… (these are all screenshots of the Easel Detail view)
@ChrisGale
I’m sure @SethCNC will chime back in, but he’s adding a pocket that cuts full depth and removes all of the extra material. He wouldn’t actually cut them that way…just manipulates the preview.
Yep, and also setting the outline that would normally be set to “outside the line” as a pocket at 0 depth.
If by this you mean the excess material, then exactly what @NeilFerreri1 said.
If you mean to the grid lines, you can select the 3 dot button at the bottom right and hide the wasteboard
