Probably one of the easiest designs possible, modeled after T1-11 siding. Drew some straight lines with the line tool to cut at 1/32" depth, and a simple rectangle to cut out the finished work piece.
It seems to refuse to cut through where the horizontal lines cross the rectangle, and also seems to not want to cut the bottom of the rectangle where it’s touching the last horizontal line.
I can get everything to work if I use a 1/32 bit and draw tiny rectangles, but it’s super inefficient and would take like 3-4x the cutting time. If I try to draw a rectangle 0.625 or even 0.63 inches wide and use a 1/6 inch bit, it doesn’t want to cut it, so that’s another issue I’m running into.
