Is the Easel Driver supported for Windows on ARM? I have a Surface Pro X (gen 1) and it will let me install the Easel Driver. I can use a USB Type-A to Type-C converter to connect it. Then Windows recognizes the device enough to show it in Settings / Devices and show that it is an “X-Controller”. But then it says below that “Driver is unavailable” and the device unmounts after 5-10 seconds. If I leave it connected, it stays in a continual mount/unmount cycle every 15-20 seconds. Is the driver even supported on Windows on ARM?
I am having a very similar issue did you ever get this resolved? I am on a surface go and it does the same thing about recognizing the device but then saying the driver is unavailable.
I’m on step 6, at 3:40 in the video. My belt is looped through the belt clip exactly as shown, and I have a good 4-5 inches of belt looped back on its self with all teeth meshin indigo credit card
