So my easel is not connected to my machine yet I’ve just been messing around with the app while waiting for machine. I have noticed however that the graph side dotted line does not match my material size I enter unless it’s less than 11”. I have purchased the x carve 1000mm will that graph change and allow me to do bigger pieces once it’s connected to the machine? Thanks for any input
that happens sometimes, try clearing your browser, unplug USB and plug it back. double check the E stop.
There’s a setting for machine size somewhere. That’s what you need.
Do this, and then you can go into Machine>Edit Machine (the image from Ken’s message above) and you can adjust the work area…
Without a machine setup you cannot edit the work area…
