1" Board. import image trace. Threshold up good solid lines.smoothing up looks good.1/23 bit 0.1 depth… depth per pass is set at 0.1.won’t pick up lines used to all day long. change it to 0.7depth. set 0.7 depth per pass picks up lines. my question is the line should be clear at 0.1 as it is at 0.7 it used to be that way cutting clock faces and never had problems like this.
Hide Material and it shows path. so will it cut right?
