Easel Only Cutting 1 Depth Per Pass and Adding Angles
Is anyone else having this issue. Today, out of nowhere, two separate projects in Easel were cutting weird. The x-carve was only cutting the depth increment and then would move on the next cut, take off a little, travel, again to the next and take off a little…
I believe this was how Easel was programmed before I began using it but it’s supposed to stay with the cut until it has gone all of the way. This is making the job take so much longer!
Also, it was cutting squares and all of the sudden cuts an angle right across the work and then completely stops.
These are jobs I have cut many times without any issue.
