Easel path issue
Hi
I have this problem where my Carvey is not cutting what is represented on Easel .
Initially I concluded that the Carvey was missing steps. But then I made 2 copies of the same design, adjusted the settings to a very conservative speed and the result is that I have the same exact mistake on both designs.
Basically some elements are not centered in the design
Check out the photos of the result and screenshot of easel for reference .
Any help is appreciated
Diego
It looks like the carved piece is kind of stretched out. Have you run a test carve of something like a simple circle to see if it is a true circle?
{:0)
Brandon Parker
