I have been trying to have easel plunge to a given depth then follow along the path I have drawn and return to the start point before raising the bit. Similar to how the keyhole app works.
Either use the line tool creating a narrow rectangle missing the 4th short side. (like a 3 sided almost rectangle shape) and then set it to “carve on path” it will plunge, make a loop and then raise back up at almost the exact same starting point, the more narow you make the shape, the closer to a perfect entry hole you’ll have.
