Thanks for the quick reply… Had purchased an alternative relay (20$) and figured I would post my setup… http://amzn.com/B00WV7GMA2
Has two normally off outlets and two outlets that come on when the automatic spindle is triggered (plan to set up the second to a vacuum system that will be automated when the spindle is on). Was simple to hook up the
Makita RT0701C 1-1/4 HP Compact Router by connecting the black and yellow wire that comes off the g-shield into the relay instead plugging into power control unit (not sure if this relay unit could handle the 24v directly from the power supply as AlanDavis has shown above)
Going to try my hand at 3D printing a mount for the Makita, but as you can see this spindle is quite a bit heftier than the inventables route.
