why is the Easel pro taking so long to generate preview?
Are you performing a 3d carve from an imported STL by chance?
Regardless, the reason is that although Easel is housed within a Browser it does not actually use off-site servers to process the toolpaths, It uses the users own PC to calculate toolpaths, so when a user has Low RAM and/or a slow processor then the toolpath calculations can take quite a while…
There are tricks to expedite the process, so if you can share your project, maybe I can take a look and share those tricks that pertain to your particular project…
(How to Share an Easel Project explained in the 2nd half of this Video)
thank you for your reply. i have a new laptop with 16 ram and 520gb I’ll try and figure out how to share it with you.
