Easel text edit
why can’t I edit the easel text? Such as Baskerville
What’s going on? If I have the text selected I can change it, I can also double click it to highlight it and edit it that way. I tested on Baskerville, seems to be working fine.
OK, apparently I asked my question wrong. Why don’t the letters in a text box have edit points? I was trying to change the letters a bit.
Oh, the text is its own object. You would need to use something like Inkscape or VCarve to ungroup and modify the shapes.
or you could use the Exploder app in Easel
See below. Top text is standard. Bottom text is after using Exploder app. Edit points are now available
There you go ^^^
I don’t use Easel a ton =p
Thanks - I forgot about the exploder app
