OK all yesterday i went to use my xcarve and it would not connect to easel… i then went to the machine setup and it prompted me to perform and update… i went thru and did this update and it all seemed to load fine… so today i try and carve… well it all starts off good… then it goes to hell…
First i have noticed with the update it changed all the bits in the bit selection area… ok thats cool
2nd i change the material type
3rd go carve and the machine is flying all over the place moving so fast so i stopped the carve and checked rates they were out of this world change material type then check speed rate no change all speeds were super fast
so i slowed them down to what they were before update and it seemed to works
so recut wood and start over … well gets to about 20% and out of nowhere it moved the whole carving up and to the right
i stop machine and it returns to the home but it does not… it goes about 5 1/4" higher up the y axis then the set home in the beginning
Please help is there a way to revert back to the past driver? this new one is not working at ALL!!!
