Easel gets to the validating window and that’s it, doesn’t go any farther. Help
Just a thought, not sure if you tried this, try clearing your browser cache and see if that helps.
I downloaded Vectric-Easel
I don’t have any issues with Vcarve v9 and Easel. Have you tried running the tool path in UGCS and see what it does?
Did you put it in the appropriate folder and use it in V-Carve? The more info you provide, the easier it is to help.
