I want to engrave some wooden nickels I got on eBay. Planning on using an 1/8" engraving bit. Does anyone have suggestions on cutting depths, type face or other settings?
Do you have a link to what you got on ebay?
I think I misspoke. A quick search found them on Amazon. About $9 /100
Might be these:
Sorry I caused any confusion. This is where I show my noobyness, how do I send a link to a conversation in inventables?
For small lettering on the discs you may be better off using a 30 deg vbit or a 1mm tapered ball nose.
Are you trying to do something like this?
This was an experiment ans is about a 50 cent piece size.
I can make them smaller but at the time this was the best I could do.
The diagonal lines were due to my unstable X axis at the time. I now have it working much better and do not get the lines anymore.
I did these small 2" coins with a 0.125" endmill for a roughing pass and a 0.25mm radius ballnose for the detail pass.
Erik:
What wood did you do that in?
Cherry…I love the fine detail that you can carve in cherry.
Eric found and sent the link to the wooden nickles, I don’t know how to send a link to here, which would be helpful to me.
The Cherry relief coins are what I am working up to. At the moment I want to start with simple text/lettering so I can give myself a reward/coin whenever i learn a new skill
I have been using Poplar. Carves better than Bass. LOL
What bit did you use and how did you clamp them down? I’m very new to this and someone asked me if I can make wooden coins and that gave me an idea for maybe using them as a “business card”?
Beautiful. Did you make this with X-carve? If so, how did you do it? What bits and did you buy them pre-made or did you cut them out yourself?
I did not make the one with the number 84 in it.
I did make the one with the pony in it.
You can make a jig that will hold a coin shape. As long as you have a way to ensure you know where the exact center is each time. You can carve the coin directly and use tabs to keep it in place after the carve.
