trying to find the feeds and speeds to engrave on 5mm acrylic and which bit is best for a newbie.
I enjoy using the Amana ZrN coated single o-flute endmill for milling acrylic. If I need to use a V-Bit, I use a 60-deg Whiteside.
Typically, you want to use cast acrylic and feed high with a shallow depth of cut. Everyone’s machine is slightly different, so you will have to hone in on what feeds/speeds work best for you. In the past, I have used the following:
1/8" Endmill
0.096" Endmill
{:0)
Brandon Parker
Thanks a million
Consider in mirror you project, engraving the back side of your piece.
