Epoxy Resin Inlay in Plywood
This may be a dumb question… are you coloring the epoxy black or painting first then using with a clear epoxy. If you are coloring it… what do you color it with?
Thanks,
I’ve tested both ways. I used acrylic paint and tempera paint. Take a look at my latest test. https://youtu.be/dp8MHbWd3Y0
This may answer some questions. I’m also planning a video using alumilite casting material. The results should be interesting
In my case I coloured the epoxy black using spray paint, just gave it a couple mists into the cup I used for mixing it all up.
Thank you for the help! It looks great!
This is a great video BTW.
Thank you. Please subscribe if you have not done so already. The alumilite casting inlay should’ve great. It will eliminate the problem with the white epoxy test. That’s the hope anyway
You can buy epoxy from LongVuResin. The quality is quite good, the price is not too much expensive.
