We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youāve provided to them or that theyāve collected from your use of their services. Learn more.
I saw that estlcam uploaded a new youtube video about the machine controll capability of this program. It has some nice features, i think the most of you find interesting.
I am wondering if i still can use easel when is do the arduino setup in estlcam.
I donāt have an xcarve. As far as I know there are many variations of the xcarve with different motors, belts and electronics - so a preset unfortunately wouldnāt make much sense.
In terms of software you canāt mess up your Arduino - if you donāt like Estlcam you can always overwrite it with something else like e.g. GRBL. The only - and unavoidable - danger is if you connect your electronics wrong or select a wrong pin layout - but again this is something presets canāt prevent.
Actually Christian, There is (I believe) only one X-Carve. There are indeed many versions of Shapeoko, of which there are two decendents of the next generation of āhobby levelā machine. The Shapeoko 3, and also the X-Carve.
I happen to own both, but I have used the X-Carve for a dozen projects, and the Shapeoko3 for NONE.
The difference is the ātool pathā or in a rookies words, the software path that has to be committed to and processed before the first chip is cut.
I have seen Eslicam online in videos, and it appears to be more sophisticated and at the same time simpler than the software provided by Inventables, or Carbide. I think either company would do well by taking your (or another company that has this figured out) and implementing a version of the software that would drive and empower their machines) and incorporating it into their own software.
Now donāt get me wrong. I think Easel is great ā¦ but it is not as sophisticated as Estlcam ā¦ so why not work together to enhance the entire universe. And at the same time, turn current Estlcam customers on to the X-Carve. Itās a win-win. And I donāt at all mean to minimize the talents or efforts of the Easel team. They are doing a really good job in user interface and simplicity. It just seems that Christian has some things worked out that would be a great addition to OUR software.
I really liked the work I saw that allowed an internal thread to be formed on a part.
The industry is expanding rapidly. I think some of the things that this software can do are an even bigger reason for that evolution in technology.
And no, Iām not German or whatever Christian is, and Iām not a paid agitator. This software just looks really good to me, and I would have already purchased it, but it appears to be PC only, and not MAC, so I have not tried it yet.
EstlCAM is a CAM program not a machine controller. You can only use it to generate Gcode using a post processor for your machine. It does not replace GRBL, LinuxCNC, Mach3, Mach4 or any of the other machine controllers out there.
It is a low cost CAM program and from what Iāve seen does an OK job of producing Gcode.
The main drawback of using Estlcam with the X-Carve is that you must flash your Arduino with Estlcamās own control code. This means that you cannot use Easel and Estlcam simultaneously. You have to choose one or the other. And once you have setup the X-Carve to use Estlcam you must reflash the Arduino to return to stock configuration. Ask me how I knowā¦
Check with TonyNo Iām fairly sure that he did two cuts of the same part. One with the Gcode generated by Easel and one with the Gcode generated by EstlCAM both on the same machine with no change to the machine.
I had to flash a new grbl in order to use the onscreen machine controls (jog buttons) in Estlcam. After this, Easel has no control over the X-Carve. Iām sure that you can still generate gcode to be used with UGCS, or whatever. But the Easel jog controls and carve button will do nothing.
@ChristianKnull should chime in here. EstlCAM supports direct, machine control when using itās own software on the Arduino. You donāt need to use it just for CAM. Think of it as a bonus, if you are interested.
You can use it as CAM to create CNC programs for other machine controllers like GRBL, Mach3 or LinuxCNC.
You can use it as machine Controller to run CNC programs created by other CAM software.
And you can use both functions together.
Estlcam will upload its own firmware to the Arduino once you click the āProgram Arduinoā button in the āSettingsā ā āUSB CNC Controllerā tab. This firmware is very different from GRBL and wonāt work with UGS or other GRBL software - so you canāt use both at the same time. But you can reprogram the Arduino with GRBL at any time if you donāt like Estlcam.
The main advantage of Estlcams machine controller is continuous jogging and Xbox gamepad support.
It also does a lot of preprocessing on the computer instead of sending the original g-code to the Arduino. This way the motion planners look ahead is unlimited and 255 instructions can be buffered in the Arduino ā very smooth program runs even if there are hundreds of code lines per second (e.g. when using trochoidal milling).
At the moment Estlcam may not work with some Arduino UNO clones because it uses 500kbit for comminication which seems to be no problem for the original but is an issue for some clones and fakes. Iām currently working on a fallback to lower speeds to solve this.
Its a completely own development written in assembler.
Its proprietary / closed source. However the machine control module can be used for free without limitations. Only the CAM functions are shareware ($50) but can also be tested without limitations for some time.
One doesnāt work without the other. Unlike GRBL the Arduino will not see a single āg-codeā line but heavily preprocessed instructions instead. Most of the work is done by the computer and only a few time critical tasks by the Arduino.
So whatās happening is the Arduino is running a simplistic task which simply accepts motion control instructions and moves the machine, adjusting for hard real time so as to coordinate motion and acceleration.
The computer is connected to the Arduino w/ a faster than typical connection and is running the G-code interpreter and motion planner and sends simplistic move instructions to the Arduino over the 500kbaud connection, keeping synched up to a degree w/ where the machine is in something approaching real time.
What motion planner are you using? Is it something you developed internally, or an extant opensource project? If so, which one?
