Expanding the x-carve size(bigger then 1000x1000mm?
Hi Susan,
qt.
2-1800mm makerslide
3-1800mm 20x40mm aluminum extrusion
2-1500mm 20x40mm aluminum extrusion
6-angle corner brackets
14ft of new belt
Thats the majority of it , I ordered 40 t nuts and 5mm button head screws (more than I needed).
Do you have a video of the build yet??
Hi David, Iā€™m still working on it , we just had a baby so Iā€™m editing it when I have the time but itā€™s almost done.
what did that run you, out of curiousity?
I put everything in a shopping cart that he listed from the Inventables website and it looks to be around $300. Since orders over $100 get free shipping thatā€™s a plus! :slight_smile:
edit: I just realized I threw a makerslide tapping kit in there as well for $35 since the 1800 makerslide doesnā€™t come pre-tapped. Take that away and youā€™re looking at around $275.
Upgrading my X-Carve https://youtu.be/odaUM6BUjo4
video is unavailable
I would like to do the same thing. I plan on ordering the xcarve 1000mm for some diy speaker builds . But I really need 1500mm can you give me some guidance on how to extend the Y axis please .
Purchase the 1800mm makerslide, longer cables, longer drag chain. Of course you will also have to extend the base frame and waste board as well. So basically just replace the 1000mm with 1800mm everywhere but the X axis.
Thank you i will give it a try once the kit comes inā€¦ maybe we can share speaker ideas at some point ā€¦:slight_smile:
Be prepared to wait 3 months for maslowā€¦itā€™s backordered like crazy.
The maslow is pretty clever and it is neat, but thatā€™s really best marketed towards entry hobbyists and people who need relatively basic shapes and patterns like cabinet builders, etc. They donā€™t even have a Z axis control last time I checked, I think itā€™s a special kit you have to order.
So I see the 1800mm makerslide on inventables site, but where do you get the taller end pieces and does anyone make a pre-drilled brace for the y makerslide so thereā€™s no droop?
Try Charley Thomas.
http://triquetra-cnc.com/shop/
Hi @DustinNull how is that you were able to make yours that long, I am wanting to expand mine, but quite unsure how to, can you ilumninate me with your knowledge?
Hi everyone Iā€™m looking for days to buy makerslides 1800mm 2040 but canā€™t find anything inventables stopped selling them. Does someone know where I could buy them ?
just spitballing here but I think might be possible to break the carve into multiple projects to increase the y axis. You just carve a fiducial mark up at the top of your first ā€œpanel.ā€ After you carve the first panel slide the work piece down, you will need to make a fence you keep you from twisting it, then manually set the home using your fiducial mark to pick up the carve where you left off. This depends on the straightness of the media, how well you make the fence and how well you can seperate the carve into 2 (or more) projects. I donā€™t think it would work on very complicated carves requiring high precision.
So Iā€™m wanting to increase my Y axis to the 1800mm but canā€™t for the life of me find where I can buy the 1800mm makerslide. Does anyone have a source? It seems as if Inventables has bailed on offering this as a part.
https://euro-makers.com/fr/makerslides/4057-profile-makerslide-wide-large-1800mm-3701172928976.html
