Experimenting with brass
tool and feed rates?
I wonder if brass could be worked small enough to make a small branding iron, say 3/4" sq. with a flamingo silhouette on it?
I bought a metallic 3x14x38 cylindrical elzet tool.
Rpm 18000 /depth per pass 0,1mm.
Should be possible is suspect, need more experimenting though.the material I used now is to flimsy for branding.
Any suggestions on where to get bar or plate brass at a reasonable price?
I used esslinger.com which seemed to have reasonable prices
http://www.esslinger.com/search.aspx?find=brass
http://www.esslinger.com/search.aspx?find=polished+brass
I buy my metals from a couple of online places, but you have to shop between each one depending on the metal/alloy you’re shopping for because prices are all over the board and shipping can be expensive.
There’s also this place, who I’ve never bought from: metalsdepot.com
If you’ve got a metal recycler near you that resells then it might be worth stopping by. Some of them will have buckets of drops/leftovers that the big boys have brought in and you can buy some good metal dirt cheap.
i got it at a metal recycler for free. i need to get some reliable sources for the future though.
First being a machinist I do not understand why you are using a burr designed for cutting wood or other soft materials in a hand held dremal.
Just to see what Gwizard had to say about machining brass.
Material = Brass 143 BHN free machining
Spindle HP= .4
Speed = 18000
Cutter = Carbide endmill .125" diameter 2 flutes .75" stick out
DOC .02" .5 mm
WOC .125
Feed rate 36 IPM 914mm/ min
Plunge rate 18 IPM 457mm/min
SFM 589
HP .059
deflection .0006"
So all of this says that using the correct cutter and parameters machining brass should be doable.
Dave
