Well my knob busted off my shifter in the truck so i decided to make one with the xcarve from some scrap wood and some scrap brass shim stock. Not perfect by any means but it will do. still needs more coats of clear epoxy before i install it.
it looks really good, good job!
Thank you
Every now and then I will use as much software as possible to make something just to keep things fresh in my mind. So for this build here is my list of software I used.
Fusion 360
Artcam
Gimp
Picsender
Piclaser
Easel
Crazy workflow I know but I forget things easily.
Tools used
xcarve
belt sander
drill press
dremel
jtech laser
table saw
son and wife (I let them pick out the materials)
I really like the shifter knob that you made. It really adds a touch of class and truly makes a statement by itself
Thank you.
How much horsepower did this add?
Great work!
Thanks. Won’t know till I hit the strip but hoping it will shave a few from launch to 2nd as I am sure the shifter will be in a slip stream from the added aerodynamics allowing a much faster dislocation of a gear along it’s spline into a higher plane of rotation. just hope the muffler bearings will hold out.
