So I have been using or trying to use F-engrave. I set my origin to bottom left and set my machine zero on material to bottom left. When I send the gcode through UGS it starts off material by 5-6". Are there any gotcha’s to F-engrave or UGS? I normally just use easel. TIA
Pictures.
With your offsets set to zero (as they are) you should be fine.
When you say “set your machine zero”, are you referring to work zero or machine zero? (I’m guessing work zero, but just wanted to check).
Which direction is the machine moving to cut in relative to the material?
That seemed to work. Thanks!
