Just a heads-up
Not sure if anyone noticed, but if you check “False Front” (misnamed, but nevertheless), it does not only remove the top drawer, but it also removes ALL drawers from the cabinet. As such, until it is fixed, if you are making a cabinet with a false drawer at the top, but actual drawers below DO NOT click on “false front”, or you will not get the drawer glide pilot cuts or the cultist for the drawers. Instead, design the cabinet as if you were going to install a full set of drawers, and then once you import the cutlist into Easel, be sure to then delete the parts for drawer #1.
Also, if the open space where the false drawer is located is to be finished (as mine is), you will need to go to the right & left sides and delete the pilot holes for the drawer slides for that top drawer.
A lot of wasted time on extra steps but is what it is.
