Finishing pass moves wrong direction
The rough pass runs correctly, but when i run the finish pass it tries to go past the work area in the wrong direction. Not sure what would change between passes.
I have a 3018 with the extension and a 300w spindle if that makes a difference.
Using Easel Pro. Its the last tab on the right at the bottom.
Hi @TomBurch,
You will need to share the project publicly for people to see it.
Do the following:
  1. Go to “Project>Share”
  2. Select “Unlisted”
  3. Copy the URL
  4. Press the “Close” button
  5. Paste the copied URL in a post.
{:0)
Brandon Parker
Sorry. I thought i had it shared. Here is the link:
