I finally had time to get some wood in the X Carve and try the 3D carving. I probably should have started with something less detailed, but I had the file on hand and went for it. It didn’t turn out very good, but I’m sure I just am missing something.
I’d love to see a preview panel to have an idea of what it will look like after rough/detail. I used a 1/4" downcut spiral for the rough and a 1/8" ball nose for the detail. I have included photos of the resulting carve and the reference image.
That still looks amazing.
Hi @JohnMorgan1 thank you for sharing this. Could you please share the easel project URL with me so I can take a look at what might be happening? Here are a few thoughts:
- It could be that the roughing toolpaths removed too much material - either from an error within the toolpaths, or due to the bit change/z zero operation.
- It could be that the 1/8" bit was too large for the detail - how big overall is the carving?
- Did you maintain the X/Y/Z proportions or was the model flattened in the Z?
Thanks, Ben
https://easel.inventables.com/projects/3pPwlWX3_I4Mqdx38x5rPQ
7"W x 7.5" tall approx.
I’m sorry for my ignorance - what do you mean in your 3rd bullet point?
Hi John. Meaning, whether you reduced the Z value only, keeping X and Y the same, to fit your model into the material size you had, making the model appear flatter.
Thanks. I’m attaching two screenshots. 1) original settings from the file, unchanged. I first started this carve and realized the material I had in place was too thin. 2) my settings - I changed based on the thickness of the material in the graphic. I used 1" thick material. #2 is what generated the carve I posted. No other settings were changed.
