First attempt - edge lit sign
Here is my first attempt. I wasn’t quite sure just how deep of a cut was needed. Using 1/4" material, routed in .09". Seems to work.
Did you use Cast acrylic?
If not use it next time you will get great results with it.
Other than that good work on the sign. :slight_smile:
