Hey all, new user here, and also new to CNC. I’m using a Mill Right King Carve 2. I’ve run into a problem with trying to cut out a design.
I have my step down set to 0.125", but for some reason my initial plunge into the material is going down .25". It attempts the first pass at this depth, but on all the remaining passes it will go back to the step down that I had originally set at 0.125.
I had a catastrophic malfunction on my CNC as soon as the machine began to move on the x-axis because of this. I repaired my machine, but now I’m trying to prevent further issues. I’ve added an image of the toolpath that shows the initial plunge, followed by the passes that are at the correct depth. Thanks for any help!
