First Relief complete!
you like?
Vectric Aspire for create g-code
Easel for machining
3 mm end mill Bit for roughing
2 mm ball nose for finishing
5 hours for entire work
Measure of piece:
600 mm x 240 mm
Depth 9 mm
Looks great!
Thanks Phillip!
Good work!
For 3D carving, to reduce carve time, one solution is to improve the Z axis in order to utilize higher acceleration rates ($122 value)
This is the main bottle neck timewise for relief carving.
Keep it up :slight_smile:
What type of wood is that??
Hi Haldor and thank You! I try It tomorrow for another work…
:sunglasses:
In Italian Is called Abete, in english I think Fir…
Have fun! Note that I dont know the capability of your machine so I dont know how much you can push these rates.
You can test performing “air carve” and check for lost steps by measuring the Z deviation from before start and after finish.
Generally you go incrementally faster untill it fail then derate that value to 80% for reliable operation.
thanks again for the advice, of course I first try on a piece of sacrifice (and Sorry for my english)…
No worries, your english is good :slight_smile:
(English is my 2nd language)
NIce! looks awesome
