What size (diameter) bit did you use for the test carve. If I remember correctly you need to use a 1/16” dia bit to get the finer details.
If the width of the letter/design is less than the bit diameter specified in Easel, it will not carve that part thats too small/narrow. You cant carve a 1/8" slot with a 1/4" bit.
