Used the x-carve to carve and filled with total boat artists epoxy. I’m very impressed with their product. If u choose to work with resins weigh each part. It will save you time and money. Also when weighed there seems to be very little air bubbles.
Quick tip on measuring the amount of epoxy required, use sand or salt, pour it into the carved area, brush off excess and measure the volume remaining
That is a great idea. Thanks!
Did you have to sand the epoxy after it was dry? To make it flush. How do you get the scratches out
