Hello
Folks
I am working on a project for a Grandchild.
I need to carve this Flat Stanley just barely marking the features, then cutting out totally.
I am drawing a blank on how to set this up.
Please advise,
Thank you.
Martin
I am using 1/4 inch birch plywood
Merry Christmas, Martin!
WOW!!! Thank You!!!
Added a workpiece with both the engrave and the profile cut in case you need to scale it.
Just:
- Scale everything together to the size you want.
- Duplicate the workpiece
- Remove the profile on the first
- Remove the engrave on the second and set to cut outside path
- Set appropriate bits
- Carve!
On that third workpiece, make sure to set the outline to cut on the outside of the path. It is currently set to cut on the path …
{:0)
Brandon Parker
Flat Stanley is on his way to the robotics competition!
Thank You to all who helped!
https://www.facebook.com/martin.gutzmer/videos/10159176039503408/[quote=“MartinGutzmer, post:1, topic:106246, full:true”]
Hello
Folks
Please advise,
Thank you.
Martin
[/quote]
