Having issue with font/s loading. Saw some old posts but no solutions that seemed to work. My issue seems to be a browser related problem. Tried using Firefox and Chrome. Tried “removing” all fonts and then trying to load. “Installed” font on another PC and it worked fine, could even use it on the PC that would not allow me to install/load earlier. Any suggestions would be much appreciated
Exactly the same issue I’m having.
Having the same problem. Please post if you find a solution. Thanks
SolutionFound the issue to be with the browser, I tried using Edge which I had never loaded Easel onto or used. So I did and everything worked in Easel on Edge perfectly. I was going to delete/remove Firefox and was prompted to “Refresh Firefox” after “Refreshing” all is working properly again in Easel.
