Frame outline before actual carve
In my laser software there is a frame option to show you where the outside boundaries of your cut will be, is there such a thing in Easel?
Would be great when you are cutting close to edges
In Easel no. In some other gcode sender softwares, such as OpenBuilds control, yes this function does exist.
However in Easel you could create a perimeter and set Z zero above the workpiece and perform an “air carve” which can sometimes sort of create the same effect…
:man_facepalming: I only now noticed that you posted into “Feature Requests” sooo yeah, I’d agree that this would be a nice added feature for Easel!!
