Does anyone have a Guideline as to what settings to use for the Inventables Carving Bit Settings in Fusion 360 with an 1000mm X-Carve 2.0 and a DeWalt 661 Spindle?
I’m lacking even the most basic information on this particular topic so yea…
The first projects I’m planning to do are things like a MDF Casing for the SSR Relay controlling the DeWalt 661 and a Plexiglas Dust Shoe. Sometime later Aluminium reinforcement brackets for the ever so popular Y-Axis Stiffening MOD.
What I meant was: “Where does one get the Bit Size/Feed Rates/RPM’s from?”
The Inventables Carving Bit Shop Page has, at best, only vague information about what a Bit can be used for and what settings to use them with. When I enter a Bit into the Tool Library I see it automatically generating some presets but can these be trusted for a DIY Machine the Software doesn’t even have information about?
So far the only assumption I have is that the lowest RPM setting I can set the Spindle to is 16’000rpm and the Dimensions/Characteristics of the Bits which is what I populate the Tool Library with but everything else? shrug
Apparently I managed to create two accounts… Ah well…
