What’s the best way to get designs in Fusion360 to the x-carve? I use a Mac, so would need a Mac only solution.
I figured there has to be a way, but surprisingly, the Youtube God didn’t really have anything…
You folks must know!
Thanks in advance.
Mark
If easel can’t do it (which I think it can!) you can use ChiliPeppr - Hardware Fiddle .
Jason
April 9, 2017, 11:45am
4
I found this:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Does-Fusion-360-Write-G-code.html
And then this:
Would someone please present a step by step procedure to import gcode from Fusion 360 into easel.
I know there are similar topics on the forum, but so far no one has given information that is helpful.
I hope I am not the only person trying to use the x-carve that does not have a good background in
computer file manipulation. I need help with every small step and every click to get from the gcode generated in fusion 360 to
running the project on my x-carve.
That should get you there (disclaimer: I haven’t done it myself… yet)
I send all Fusion360 toolpaths through Easel. It will show you the toolpaths before cutting anything if you’ve imported correctly.
I do the same.
I am also on Mac, design in F360 and generate tool paths for my carve in F360, with the appropriate Easel post processor (PP). You can find this @ https://inventables.desk.com/customer/en/portal/articles/2332499-installing-a-fusion-360-post-processor-on-a-mac?b_id=9563
Then import the gcode exported from F360 into Easel and use Easel as the gcode-sender.
Thanks all… I have been exporting gcode from F360 to Easel with good success, just needed the right post processor. Appreciate the help.
Mark
