We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youāve provided to them or that theyāve collected from your use of their services. Learn more.
I have started working with F Engrave a bit and one of the problems I ran into is that the G-Code created by F Engrave contains command lines over 50 characters long. The documentation from F Engrave suggests that changing the #3 value in GRBL from 50 to 80 will fix the command length problem.
I have also run into other programs that generate long command lines (usually comments)
My question is will changing the #3 value to 80 have any negative impact on Easel?
Select the āDisable Variablesā check box in the F-Engrave Settings window
un-select the āEnable Arc Fittingā check box in the F-Engrave Settings window
Use F-Engrave version 1.34 or higher
āError while starting file stream: Command #3 too long: (55 > 50) ā(Settings used in f-engrave when this file was created)ā ā
GRBL Error
This error is generated because the #3 value set in GRBL is 50 and it need to be increased to allow longer g-code lines to be processed. Setting the #3 value in GRBL to 80 should be sufficient to accommodate the g-code generated by F-Engrave. (Thanks to Barry W. for this information)
I donāt think that you should change the grbl value. The recent versions of Grbl use a different settings map. Look at the most recent one here. Configuring Grbl v0.9 Ā· grbl/grbl Wiki Ā· GitHub
You can configure the line length as a compile option in the Grbl source, but I donāt think it can really be increased because the Arduino memory is so limited.
There is no #3 option for Grbl. It has a hard limit of 50 or 70 (79) characters per line due to limitations of the Arduinoās memory capacity. Moreover, Grbl uses $ to indicate its settings options.
Iām getting this error now with UGS nightly build (9/2017) , v1.1f of firmware on a 3d carve. Iāve seen this occasionally, and just retrying it a few times seems to āfixā it, but now I canāt get past it.
The error was a :NULL. I moved from the Platform (.exe) to the .bat script which calls the .java script and itās working. Go figureā¦ Platform vs. Classic. Classic works and Platform doesnāt.
