Ganesh 3D Relief
Here my new relief
X-Carve 1000x1000
Wood: Fir
Bit: Ball Nose 2mm (radius) for entire work
Time: 3,5 hours
Dimension (in mm) 300x210x35
GANESHA.gcode (9.3 MB)
gcode attached (in mm)!!!
Starting point low left angle
tip spaced from a sheet of paper from the material
Hope you like and enjoy!
Ciao
P.S a big thanks to @HaldorLonningdal for advice
very cool! I’d like to try this for my first 3d carve but
when I import it into easel I see almost a total field of blue or carved space, is this correct? See attached screenshot
@JeffHunt, you’re removing a lot of material in that carve. Zoom in and look at the preview from different angles.
Ciao!
sorry for the time for the answer …
as he says @NeilFerreri1 his is normal; zoom it and you can see the figure.
Hope see your Ganesh, I whait!!!
See you.
Ciao
