Made this garage sign for myself, as you can see in the pictures, I am a big Ford fan. Made this out of a piece of Select White Pine from Lowes.
Very nicely done.
Sorry to hear about that Ford affliction though.
great sign and nice finishing, could you give a brief run down on your painting and finishing
Thanks
Here is the video of me making it.
Nice work Dave, I’ve had you subscribed on youtube for a while now.
Are you able to provide me with a link to the exact bit you use on most of your carves. I have seen you reference an Amana 90 deg a couple of times.
Is it this one? https://www.toolstoday.com/p-6015-in-tech-series-insert-v-groove-router-bit.aspx
Yes that is the one, they work great
I use the same cutter.
It works great and the inserts are cheap enough too.
@DavidDHoard So I picked up this router bit and its working pretty good but I seem to have more chip out in the thin areas (cutting pine) than I did with my 60 degree that I was using previously.
Would you be able to share your speeds and doc settings?
Thanks
Tim
Tim, I usually run a 40 ipm with a depth of .08 per pass.
Thanks, I’ll give it a shot like that.
Tim I also forgot and made a cleanup pass on the v-carving as deep as the cutter will allow. Aspire let me set it at .344 deep, this helps clean up some of the lines
