Would like to know if there is anyway to get a better graph scale on the left and right layouts in Easel…Was needing more than once for placement of images… Like 1/4" or 1/8" increments…The way it is now I can only Guess between 1" increments…When doing not centered images it is difficult to determine where it is correctly…
Hi Kim, Not sure if this will help, but on the Shape Tab you can enter the coordinates for discrete movements rather than eyeballing locations of items.
The location of the item referenced (red box in my photo) can be set to center or any of the 4 corners depending on your alignment needs. And then you would manually type in the desired coordinate position for X and Y (shown in the green box of my photo)
