Has anyone experienced Grbl settings not holding from session to session? I’ve upgraded to the new Z Axis and $102 was changed to the recommended 49.909. The next time I use the machine, it has returned to the prior setting.
Don’t run the setup.
Thanks. Interestingly I didn’t run the setup activity. I just changed the Grbl setting for $102.
Your changes will persist until you change them or run the setup in Easel. There are other senders that might change them as well.
