Great Make: article on converting a STL file for laser cutting
Like the title says, Make: has a great article up on converting a STL file for laser cutting. This should work well for CNCing also as long as you take the tightness of the cuts and the corners into account.
If you use meshcam it’s even easier, and you can choose the heights
+1 for the ease of MeshCam to converting an STL to tool paths.
