Does anyone know if you can make the grid boxes smaller. Thanks
Hello @DougFranz, you can not change the size of the grid. You can only switch between imperial and metric.
{:0)
Brandon R. Parker
DougFranz
If I understand your Question right.
You can zoom in on the screen and there will be more graduation marks between measured increments. Whether your using imperial or metric
I see the same amount of grid lines no matter my zoom level. The only thing that changes for me is the number of lines that have numbers next to them due to space concerns.
Zoomed Out - Imperial
Zoomed In - Imperial
Zoomed Out - Metric
Zoomed In - Metric
And…Zoomed way Out - Metric
The same number of grid lines are present, but only one number every 100mm is present.
{:0)
Brandon R. Parker
Brandon
Here are two screen shots of what I was talking about.
I hope this helps.
I’m using Microsoft Edge as my browser.
Dale
Thank You
