Has anybody made a Celtic coaster
Celtic Weave Design001
That looks fantastic. Did you do that? If not, are you looking for a pattern to do something like this?
Yes, I would like to figure out how to make that pattern in Easel
I would bet that coaster was made using a scroll saw to make all of the though slots and the 3d effects added afterwards with a Dremel tool. Those 3d effects are going to be the more complicated part to get right within Easel. And the smaller slots might be impossible given the bit diameter, that’s why I think a scroll saw was used, since the saw blades are much smaller and not rotating the way bits do…
The photo matches this entry in Pinterest that seems to be from Vectric
but I’m with Seth in that I don’t see how this was CNC produced without a 5 axis machine.
These might be more approachable from a CNC perspective.
Yes, basically, I am looking for how to make the smooth tapering down cuts, which when aligned, would give the impression of a Celtic Knot.
Hello Martin,
If you look on ETSY you will find one person who made STL files of these.
Bert Klappe
WOW! Thank You!!
