Bonjour,
je ne trouve pas le paramètre pour éviter que la fraise ne remonte de 4 cm à chaque étape alors que 1 suffirait !
Merci pour votre aide
Bonjour,
Hello,
I cannot find the parameter to prevent the router from rising 4 cm at each step when 1 would be enough!
Thanks for your help
Perhaps you are referring to the safety height. This determines how high up the router is raised to clear clamps and the workpiece when the router is moving to a new place to cut. This is set in the “Machine” tab by clicking on “Advanced”.
Other than that, it might be a controller setting where you need to calibrate the stepper motor steps. Z is set by the $102 variable.
I concur, sounds like a mismatch between step/mm AND/OR microstep setting.
