XCARVE PRO - XCARVE 60 VCARVE BIT (30655-02 V-Carve bit ), test on first easel project.
Problem: The V carve using EASEL ( I chose the one indicated in the tutorial) and it didn’t clean out the cut very well. Did two passes but still the material you see is attached. New everything bits, X-Carve Pro …
First cut ever, not sure what to do I hope this isn’t normal - the clean up time is going to be a bunch - Advice? Thanks!
I guess I would suggest two things, Get a bit that is designed for plastics. Play with your depth of cut and feed rate. My experience with HDPE is the cut will be fuzzy at the top.
I cut some hdpe the other day for someone.
Not v bit carving but I figure since it’s hdpe related I’ll leave the feeds and speeds I had success with here
Zero flute 1/4" 75ipm 20in/min plunge .12dpp
3.5 speed on Makita router - onefinity journey man
Idk if its residue or residual hdpe but the lines don’t look crisp on OP pics. Something isnt right with those speeds and feeds. A proper bit would help eliminate the melted plastic look as well as dust collection.
