Ok…so here’s what you should do…
Remove the SC outline from the first work piece.
Remove the V-Bit as the detail bit from the first work piece.
Change the primary bit to V-Bit 90° on the first work piece.
Remove the V-Bit as the detail bit from the second work piece.
Carve the first work piece design with V-Bit.
Change bit
Carve the second work piece cutout with other bit.
{:0)
Brandon Parker
