Help cutting text (monograms) [Solved]
Trying to cut a monogram from a vine font. I ran the font through inkscape and imported the svg. However, when I cut it Ido not want it to follow the path of the letters. I want it to consider the 3 letters as one solid object otherwise it will slice the letters up as it cuts.
How do I fix this?
In easel select everything and go to Edit -> Combine…that should work.
Solved. Thank you! Been struggling with that all night.
